Novation Twitch Controller
Обсуждаем и выбираем звуко-, свето-, фото- и другую аппаратуру. НЕ ДЛЯ ОБЪЯВЛЕНИЙ!
Модератор: faza
Уважаемые пользователи!
В этом форуме запрещены объявления (для них существует Частный сектор) и абстрактные темы "Помогите выбрать" и т.д.
Dreaming
Сообщение Dreaming » 30 июл 2011, 18:10
Novation Twitch Controller Details
Novation Twitch is a DJ controller with a completely new take on DJing. The worlds of digital DJ and Controllerist are colliding; performers are looking for new ways to manipulate music. Twitch has Touchstrips to navigate tracks and you can slice-up your beats and mix them back together – totally on the fly. Twitch has a built in audio interface which is absolutely rock-solid with high-level headphone and main outputs.
Instead of simply mixing tracks together with 'decks in a box', Twitch re-focuses on cutting up beats, glitch-esque looping, firing off cue points and getting a totally different level of control over FX. Twitch has been co-developed with Serato and comes with ITCH DJ software, which is ultra-stable and has some powerful performance features, including the ability to beat-match your tracks so you can do some incredible remixing in real-time without falling out of sync.
Twitch has Touchstrips; simply grab your tracks and swipe them backwards and forwards like a touchscreen. The performance modes create totally new ways to manipulate beats and breaks. The control surface - with its 2 x 8 large Triggerpads and Fader FX - opens up awesome possibilities for digital DJs and the new breed of Controllerists.
Novation Twitch Controller Specifications
Спойлер
Mixer section
8x pots: EQ and trim
[spoiler]Mixer section
2x channel faders
1x replaceable crossfader
2x Continuous rotary encoders
2x headphone assign buttons - enables respective deck in the cue mix
2x Fader FX assign buttons
Master section
4x pots
Headphone level
Master/cue mix
Booth level
Master output
Controls per deck
Touchstrip with swipe and drop modes
Continuous rotary encoder for pitch +/-
Cue button
Play/Pause button
8x Large Triggerpads
4x performance mode selector buttons
2x Beatgrid buttons
2x sync/keylock buttons
Master FX section
1x Pot
2x continuous rotary encoders - right hand is also tap tempo/left hand is pressing makes for secondary parameter control
6x FX select buttons
Mic/Aux input section
1x pot
1x on/off button
1x assign to headphones button
Audio Interface
24bit at 44.1/48KHz
2x master outs (L/R) on balanced TRS jacks
2x booth outs (L/R) on phono jacks
2x aux input (L/R) on phono jacks
1x aux gain pot
1x direct monitoring switch
1x mic input on TRS jack
1x mic gain pot
2x headphone outputs (1x TRS jack & 1x 3.5mm jack) both can be used simultaneously)
1x Master/cue switch to change signal going out of Booth outputs between cue & main
1x direct monitoring output - bypasses the software and passes mic/aux input straight to the main outs
Стоимость девайса 500$.Начало продаж 8 августа этого года ...
Tanz Demokratur!
Вернуться в «Железо»
