8 Care When Bleaching Hair
shuklarani77
Сообщение shuklarani77 » 28 сен 2022, 13:16
The process of bleaching hair is quite common, but if it is not done properly and with trained professionals, the result may not be what you expected. Everyone can change the look, but it's important to take some care to maintain the beauty and health of the wires. There are some techniques that can be applied before and after the procedure. Discover, in this post, 8 care when bleaching hair and learn how the process works! Know and understand that there is a difference between dyeing, coloring and discoloration Let's first understand that coloring and dyeing are the same thing, bleaching is another. Coloring occurs when there is the use of a chemical based product capable of inflating the hair fiber, opening scales and facilitating the pigment to set on the wires.
It can be permanent, temporary or semi-permanent. In bleaching, the product removes the pigment from the thread, reaching the desired lightening background for the hair. Among the components present in bleaches is persulfate, which acts together with the oxygen present in hydrogen peroxide, destroying hair pigments. That is, the discoloration is carried Whatsapp Number List out from the oxidation of the pigments present in the hair fiber. Both procedures (coloring or bleaching) cause damage to the hair, hence the need to use quality products, capable of coloring or bleaching, minimizing damage to the hair. It happens that the chemical process causes the locks not only to lose pigmentation, but also mass, lipids and proteins. For this reason, we recommend hair treatments to improve the appearance and health of the hair.
Strengthen strands with a pre-chemical treatment A pre-chemical treatment will ensure that the yarn develops more resistance to the bleaching process, which, by its nature, is very aggressive. Treatments based on nanoparticles will guarantee an immediate result when we talk about replacing the mass and returning the mechanical strength to the yarn against eventual breakage and rubber rubber. Use protection while bleaching There are products on the market that protect the fiber structure during bleaching and ensure that the hair goes through this procedure more safely, maintaining health, considerably reducing the risk of hair breakage and rubber.Use and abuse these products, they guarantee perfect discoloration and minimal damage.
Сейчас этот форум просматривают: нет зарегистрированных пользователей и 141 гость
